Hi all, new here and sadly expericing a problem I have not seen before. I bought a new PC (spec at the bottom of the post) in late 2021 which has hardly been used since purchase due to work reasons/not being in the house. It has worked and been capable of being on for 10+hours, but like just mentioned it hasn't been used daily/reguarly, probably only 100 hours since purchase.
This week I have turned the PC on for the first time in weeks. It booted up, logged me in and everything seemed normal. Then I noticed my PC monitor said nothing was detected and seconds after, the PC would turn off. It's like it shut down rather than the power was pulled and it instantly turned off. I will power on the PC and it will start to boot, 30-40seconds later the same will happen, just turn off. Last night this happened 3x in a row, then the 4th time it loaded up fully and I was able to start using the PC for around 5 minutes before the same thing happens. Why would it behave in this way, does anyone have any ideas or suggestions?
It's under warranty and I can take it in for checks, but am i being silly here, is there something i am missing?
The PC was plugged into an adapter but i plugged directly into a wall socket and the same occurs.
I can post a video to display the issue if allowed, however i won't be able to till this evening at earliest.
Thanks all in advance for replies
Specs below; (Prebuilt by OC UK, not by myself)
Description: OcUK Gaming Rapier - AMD Ryzen 5600X, GeForce RTX 3070Ti Gaming PC
Kolink Modular Power 700W 80 Plus Bronze Modular Power Supply 1
Phanteks Digital RGB LED Strip - Combo Set 1
Phanteks Eclipse P360 Air Mid Tower Case Tempered Glass DRGB - Satin Black 1
OcUK Value Power Adapter 3 Pin Fan Power to 4 Pin Molex Adapter (RB-523) 1
AMD Ryzen 5 5600X Six Core 4.6GHz (Socket AM4) Processor - MPK 1
*Build Stock* Gigabyte GeForce RTX 3070 Ti Gaming OC 8GB GDDR6X Graphics Card 1
TeamGroup 1TB Vulcan G SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive 1
Seagate BarraCuda 2TB 7200RPM 256MB Cache Hard Drive - *System Stock* 1
Asrock B550 Phantom Gaming 4 AC (AMD AM4) B550 ATX Motherboard 1
Crucial Ballistix 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit 1
Microsoft Windows 11 Home 64-Bit DVD - OEM (KW9-00632) 1
**Promo** Cooler Master MasterLiquid Lite 240 AIO CPU Cooler - 240mm
