new 9600gt cooler
4 Aug 2008
Waterlooville
ive jsut bought a 9600gt and am not too impressed with the cooling
what are my options to help get it cooler
i have water cooling, one loop with just the cpu cooled swiftec block, dual bay res d4 pump,1 single 120 and a double width 120 rad
i dont want to spend too much less than £45
i was looking at one of these n thought it might be quite good
linky
Ohhhh a free copy of grid that could be a bad thing! :D
Also how do i know that either of them will definatly fit my card it doesnt say it will on ocuk will any 8800cooler fit?
the ac one is meant to cool the memory too how is that does it have a large base or is it from the large cooler passivly cooling the area?
ok ive answered my own question above
but is this thing really wider than it is long! 138mm long and 215mm w! that wont fit in my coolermaster elite 330!
ive been looking at it more and think that they are looking at length and width different to me else its nearly 2x as wide as it is long and on the ac site when you look at the installations pics on a 8800 its clearly longer than it is wide so should be fine im ordering it now from oc with the turbo fans they might b abit load bout think i might aswell
