Hi all,
I've recently put together my first new build in about a decade and everything seemed to go pretty smoothly apart from the thread title.
CPU: 9900x
Mobo: MSI MPG B850 EDGE TI WIFI
Cooling: Lian Li HydroShift II LCD-S 360CL
CPU Idle: 50°
CPU after 1min of Cinebench: 95°
Case temps: 30°
Water temps: 25°
I wondered if I had put on too much thermal paste (the generic one that came with the cooler) and after taking the cooler off and checking, yes, i probably did. I've now scraped off most of the excess and only have a thin layer but it didn't do anything to help with temps, if anything they are slightly worse.
I still wonder if it's a thermal paste issue, so I've ordered some Arctic Silver 5, but in the meantime I wonder if anyone else has any thoughts on what the problem could be?
Thank you
CPU: 9900x
CPU Idle: 50°
Case temps: 30°
Water temps: 25°
Thank you
