Greetings,
Firstly, apologies if this is not technically in the correct area on the forum (seemed to be the best fit)
I'm looking for a new CPU cooler - Currently running an AMD Ryzen, with stock RGB cooler (nothing special) I've been shopping around for a while, but a hard choice to make.
The case I'm using is the Phanteks Enthoo Luxe White - So has the capacity for 240mm & 360mm radiator.
Cost isn't a huge factor, as most sit around the same price (£100 to £150.00 ish) but so much to read on.
Ideally, looking for the Fans/CPU cover to be RGB (just to match the rest)
E.G - Using ML fans, 360mm, RGB.
https://www.corsair.com/uk/en/Categ...UM-SE-240mm-Liquid-CPU-Cooler/p/CW-9060041-WW
Love this one, White (to match the case) RBG fans, although it's 240mm. And it's using LL fans, which I know are good.
https://www.coolermaster.com/catalog/coolers/cpu-liquid-coolers/masterliquid-ml360r-rgb/
