- 2 Jul 2015
- Hampshire
I have an AMD FX-8350 processor, an Asrock 980DE3/U3S3 mobo (not the best im aware, tempted to upgrade let me know if this will help) and a brand new Silverstone Tundra TD02-Slim AIO water cooling unit (recommended to the Tundra TD-0x range by a friend who had almost silent cooling and worked very well). Having installed my water cooler today and used Arctic MX4 thermal paste, my PC automatically shut itself down randomly. I assumed it was an overheat so I removed my side panel and felt the two tubes and both were very hot. I checked the direction of the fans that I installed on the radiator and they were correct, I checked all the fan leads and pump were plugged in and all was fine. However it still seemed to shutdown due to excessive use. At the time I had CS:GO and Teamspeak and Chrome open, nothing too demanding, especially for my 4GHz 8core CPU. I left it to cool and came back earlier and turned it on again, this time leaving my side panel off so i could check the temp of the tubes at random points. For the first 10 minutes one was hotter than the other as would be expected, but then after 10-15 mins they both warmed up very quick. I have a feeling something could be wrong. Can anyone help. Let me know if you need more details, or if you suggest getting a new mobo, AM3+ socket is needed. Thanks in advance.
