New air cooler
26 Jun 2003
Plymouth
Hi guys,
I am in need of a new air cooler for my cpu.I am using at the moment an akasa revo cooler which I am not happy with.
Could you please recommend a new cooler for me that will fit my Lian-Li PC-60 Plus case,motherboard and possibly to run as quiet as possible.
At the moment the system is not overclocked,but if I get a decent cooler I may think about it in the future.
Many many thanks :)
I have been looking and reading all across the web and I have been looking at the Prolimatech Megahalems CPU Cooler,could anybody please tell me if this would fit my case okay.
Im not sure if the corsair h50 counts as air or water?
but its as easy to install as air ... so im posting it...
I just moved from a zalman lump of copper poo to this glorious thing..
quiet .. very cold.. and something about pipes in your system just feels cool.
I would defo recomend the H50
and best of all its on offer this week for ocuk
Thx for the replys guys will have a look at the website,and I have looked at the H50,but I think I would have to change my case,but not too sure ?
I've got a Coolmaster V8 fitted in my system and can highly recommend it. Runs really quite and can cope with moderate overclocking no problem. A big lump!!... so just check for clearance dimensions on side case mounted fans first.
