**NEW ALPENFOHN AIO COOLER DEVELOPED WITH DER8AUER**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi All,
Alpenfohn recently decided to join the AIO market creating a cooler alongside overclocking expert der8auer and is suitable for overclocked systems as well as for silent operation.
The Glacier Water 240 from Alpenfohn has been optimized for high performance and quiet operation. This is ensured by the 27 millimetre thick aluminium radiator, the well thought-out construction of the pump unit and Wing Boost 3 ARGB 120 mm fans.
The two-chamber design of the pump unit lowers noise emissions and also increases performance and service life. The base plate made of copper has large micro-channels, which ensures rapid heat transfer to the coolant. The pump works between 1,200 and 2,550 rpm and is therefore equipped for both silent operation and overclocking projects. In doing so it reaches a maximum volume of only 17.8 dB (A).
Together with the PWM-controlled 120 mm Wing Boost 3 ARGB fans, quiet operation with maximum cooling capacity is guaranteed. The fans work in a speed range from 500 to 1,600 rpm and convey up to 92.19 m³ / h (77.92 cfm) in air with a static pressure of up to 2.19 mmH2O.
Available in Black and White:
Alpenfohn Glacier Water 240 White High Speed ARGB CPU Water Cooler - 240mm @ £159.95 inc VAT
Premium AiO coolers, made for overclocked systems, near silent operations, White in Colour, Thermal Grizzly Hydronaut thermal paste included, 2 Year Warranty
Only £159.95 inc VAT.
ORDER NOW
Alpenfohn Glacier Water 280 White High Speed ARGB CPU Water Cooler - 280mm @ £169.99 inc VAT
Only £169.99 inc VAT.
ORDER NOW
Alpenfohn Glacier Water 360 White High Speed ARGB CPU Water Cooler - 360mm @ £179.99 inc VAT
Only £179.99 inc VAT.
ORDER NOW
Alpenföhn Gletscherwasser 240 CPU Water Cooler - 240mm @ £144.99 inc VAT
Premium AiO coolers, made for overclocked systems, near silent operations, Thermal Grizzly Hydronaut thermal paste included, 2 Year Warranty
Only £144.99 inc VAT.
ORDER NOW
Alpenföhn Gletscherwasser 240 High Speed CPU Water Cooler - 240mm @ £149.99 inc VAT
Only £149.99 inc VAT.
ORDER NOW
Alpenföhn Gletscherwasser 280 High Speed CPU Water Cooler - 280mm @ £169.99 inc VAT
ORDER NOW
Alpenföhn Gletscherwasser 360 High Speed CPU Water Cooler - 360mm @ £169.99 inc VAT
ORDER NOW
Alpenföhn Gletscherwasser 360 CPU Water Cooler - 360mm @ £164.99 inc VAT
Only £164.99 inc VAT.
ORDER NOW
The blue/green one has ARGB according to the product pages.
The only difference I spotted is one is called high speed, I’d expected one has ~1200 rpm fans and the other had ~2000 rpm fans but the fan and pump specs look the same
