- 5 Jul 2025
- UK
I've just completed a new build and am now tearing my hair out at its failure to POST.
Components:
Motherboard: ASRock PG Lightning B650 with a sticker saying 3.10
CPU: AMD Ryzen 9 7900X
RAM: Patriot Viper Venom 2x16GB CL30 6000
PSU: MSI MAG A850GL PCIE5
GPU: Zotac GeForce RTX 5070ti SOLID CORE OC
Symptoms:
On first powering the system on, all case and CPU fans spun up and the POST diagnostic LEDs on the motherboard illuminated for some time as expected, before eventually all extinguishing. At this point I had the monitor connected to DP1 on the GPU but saw no output. Interestingly (maybe?) the GPU fans didn't spin at all, and there's no sign of the "power safety LED" that the GPU claims to have (should be green if the power lead is connected correctly, red otherwise). Subsequent power on attempts have the same end result but with less time waiting for the LEDs to extinguish.
What I've tried, roughly in order:
Any help would be much appreciated
Components:
Symptoms:
- All other ports on the GPU (DP and HDMI), plus the HDMI on the motherboard - no output on any.
- Reset the CMOS using the jumper - returned to an longer LED phase on the next power on, no other change.
- Disconnected all drives from both the PSU and motherboard - no change.
- Disconnected the GPU from the PSU - no change.
- Reseated all power leads - no change.
- Removed the GPU entirely - no change.
- Removed 1 stick of ram (tried in both A2 and B2) - no change.
- Removed all RAM - CPU and DRAM POST lights stay illuminated, which I guess is expected, perhaps not the CPU one?
- Updated the BIOS to 3.30, the latest available - longer LED phase on next power on but otherwise no change.
- Downgraded the BIOS to 1.03, the version that was validated against my CPU - as above.
- 24 pin ATX (16+8 at the PSU) to the motherboard
- 2x 8 pin CPU to the two CPU power ports on the motherboard
- 12v 2x6 to the GPU
