New AMD mobo with 8 SATA reqd - HELP!
9 Oct 2010
Hi
Need to upgrade my MOBO as my needs for HDs risen to 8 SATA, 1 IDE HD and
1 IDE DVD Burner
Due to cost issues, need to reuse my AM2+ processor and 2x2GB dual channel ram.
So, I NEED
- 8 Sata ports - each to be used and NOT raid
Minimum of 10 USB ports
1 x firewire
1 x serial
Form factor not an issue but ability to o/c somewhat is.
Lastly, as it sits on my desk 300mm from my head, I'd like to be able to control my fans to minimise noise.
Thanks
At some point you just have to stop re-using those old small HDDs and just bin them ;). Or am I missing the point? :) How can you 'need' 9 HDDs???
As above - just add an extra controller.
