** NEW AND COMING SOON FROM OCUK TECH LABS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Launched yesterday, OcUK Tech Labs Watercooled Memory Kits.
This is a performance memory kit that we fit with proven memory cooling solutions for watercooling enthusiasts.
Starting with a best selling Black Dragon 8GB kit from GeIL, the OcUK Tech Labs Watercooled Memory Kits are designed to be as easy to plug and play as a standard memory kit. Just link the block up into your loop and enjoy the extra overclocking headroom that the watercooling allows.
We also offer additional modules if you wish to fill your memory slots.
This range will grow over time and myself and Gibbo are working with our best selling memory partners to offer OcUK customers a range of memory modules that come with crazy speeds, aggressive timings and awesome aesthetics.
Over time, we will be adding to the range of RAM blocks also.
OcUK Tech Labs Watercooled Memory Kit - GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) @ £97.99 inc VAT
OcUK Tech Labs Watercooled Memory Kits are picked for reliability and overclocking performance. Each memory kit comes complete with a performance proven Watercooling solution from XSPC.
This set includes an XSPC memory waterblock, and two memory modules fitted with high performance XSPC heatsinks.
GeIL announces the launch of the new DDR3 Dragon RAM Series to be added to GeILs’ performance memory line of products. Not only does the Dragon RAM is tattooed with the GeIL dragon totem and crowned with two red LEDs as the dragon eyes, the PCB is eight layered instead of the usual six for maximum stability. As GeILs’ quality standard, the Dragon RAM will be reinforced with DBT – Die-hard Burn-in Technology for the highest quality assurance. Covering the most popular specifications of DDR3 today - 1333MHz and 1600Mhz, the Dragon RAM is the answer to an added value solution for the mainstream market.
Features:-
- PC3-12800 1600MHz CAS 11-11-11-28
- Designed for PC
- GeIL classic Dragon design
- 1.50v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge/Ivybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £97.99 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) @ £69.98 inc VAT
OcUK Tech Labs Watercooled Memory Modules are picked for reliability and overclocking performance. These modules are designed to be used with an XSPC 4 Slot Memory Waterblock and are an ideal way of adding more modules to your OcUK Tech Labs Watercooled Memory Kit
This set includes Two memory modules fitted with high performance XSPC heatsinks.
Features:-
- Designed for PC
- 1.50v VDIMM
Only £69.98 inc VAT.
ORDER NOW
The prices sure are affordable if you are into that sort of thing. But a question:
How do you know if your memory OC fails due to temps and not bad modules? How often does that happen?
the prices are designed to offer no added cost to the customer. if you purchased the ram blocks and the modules together, you essentially get the Tech Labs assembly service free of charge.
memory overclocking failures can be down to a number of factors. heat is generally second to a weak IMC or a poor overclock setting.
Whilst these modules are not guaranteed past the rated settings by us, most 1600mhz modules are not actually speed binned by the vendors due to the cost involved.
essentially, having active cooling on your modules eliminates the factor of heat causing the memory to fail the OC.
It isnt 100% required for 1600mhz memory as DDR3 is pretty cool running. however, for people overclocking 2000mhz+ it is certainly a good idea
Thanks for the conclusive response.
I do admit I am not into watercooling (selfmade loops, maybe someday...) but I wanted to hijack the thread for general memory information :P
Cheers.
Will there be other memory options to come as the current ram avaliable seems to be a bit poor seeing as its c11 and only 1600mhz. Were they chosen as they did not come with heat sinks as standard making installation easier?
they were the first ones to put live as they are actually one of our best selling memory skus
the fact they dont have heatspreaders already is just a bonus.
I am putting more live as we speak.
some Avexir has just gone live.
i will be adding faster binned modules later as well as different block options using the EK blocks.
OcUK Tech Labs Watercooled Memory Kit - Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) @ £99.95 inc VAT
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black high performance heatspreaders
- Blue LED Strobe lighting effect (See product images)
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
* Please note, whilst these memory modules do have LEDs on them, they will not be visible when the waterblocks are fitted.
Only £99.95 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) @ £73.99 inc VAT
Features:
- Black PCB
- Lifetime Warranty
Only £73.99 inc VAT.
ORDER NOW
Ahh right. Looking forward to really extreme options like the 2400mhz or more ram.
The tech labs bundles really are great for people who may not be confident enough to tear their brand new parts apart to fit the blocks. Keep it up guy's!
Added a few more SKU's today with faster memory frequency.
OcUK Tech Labs Watercooled Memory Kit - Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CI) @ £139.99 inc VAT
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CI) - Blue Light
Features:
- Black PCB
- CAS Timings: 10-12-12-31
- 100% tested at 2400MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £139.99 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CI) @ £114.95 inc VAT
Features:
- Black PCB
- Lifetime Warranty
Only £114.95 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Kit - Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) @ £135.95 inc VAT
Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light
Features:
- Black PCB
- CAS Timings: 9-11-10-27
- 100% tested at 2133MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £135.95 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) @ £105.95 inc VAT
Features:
- Black PCB
- Green LED Strobe lighting effect
- Lifetime Warranty
Only £105.95 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Kit - Avexir Venom Series 16GB (2x8GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330908G-2CIG) @ £199.99 inc VAT
Avexir Venom Series 16GB (2x8GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330908G-2CIG) - Green Light
Features:
- Black PCB
- CAS Timings 9-11-10-27
- Lifetime Warranty
Only £199.99 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - Avexir Venom Series 16GB (2x8GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330908G-2CIG) @ £175.99 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £175.99 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Kit - Avexir Core Blue Series 16GB (4x4GB) DDR3 PC3-19200C10 2400MHz Quad Channel Memory Kit (AVD3U24001004G-4CI) @ £249.95 inc VAT
Avexir Core Blue Series 16GB (4x4GB) DDR3 PC3-19200C10 2400MHz Quad Channel Memory Kit (AVD3U24001004G-4CI) - Blue Light
Features:
- Black PCB
- CAS Timings: 10-10-10-27
- Quad Channel Kit: (4x4GB)
- Lifetime Warranty
Only £249.95 inc VAT.
ORDER NOW
OcUK Tech Labs Watercooled Memory Modules - Avexir Core Blue Series 16GB (4x4GB) DDR3 PC3-19200C10 2400MHz Quad Channel Memory Kit (AVD3U24001004G-4CI) @ £225.95 inc VAT
Features:
- Black PCB
- Lifetime Warranty
Only £225.95 inc VAT.
ORDER NOW
