- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
There is a new king-ding-aling is in town from next week, Antec have finally listened and have designed a new case which isn't ugly. (like some of their recent case products). The 100 is similiar to the classic Antec 300 but with an all black interior, SSD mounts as standard and a large CPU backplate cut out. This case is better than the Antec 300.
BEST OF ALL IT IS CHEAPER THAN THE ANTEC 300 TOO.
Antec 100 One Hundred Ultimate Gaming Case - Black @ £46.99 inc VAT
Antec’s One Hundred is the gaming case that delivers high-end features at a price that won’t break the bank. Eight expansion slots provide exceptional expandability, and can accommodate multiple video cards. A sleek painted black interior with clean, perforated front bezel houses your components in style, while the four top USB ports with audio in/out and handy storage tray bring convenience and accessibility to the package. Finally, the bottom PSU mount, two included TwoCool™ fans and washable fan filter keep your system cool and quiet. Antec’s One Hundred provides a wealth of in-demand features while keeping you within your budget.
- Bottom-mounted power supply isolates heat and noise
- Perforated front bezel delivers maximum air intake
- Includes standard case lock slot for integrated anti-theft protection
- CPU cut-out allows for easy installation of CPU coolers
- Cable management compartment organizes cables discretely
- Convenient top accessory tray
- Cable management ties keep your case organized
- 6 x internal 3.5” HDDs
- 3 x external 5.25” HDDs
- 1 x internal bottom-mounted 2.5” SSD drive
- 8 expansion slots for plenty of flexibility
- Cooling system
- 1 x top special 140 mm TwoCool™ fan
- 1 x rear 120 mm TwoCool™ fan
- 2 x front 120 mm fans for HDDs (optional)
- 1 x side 120 mm fan for graphics cards (optional)
- Front ports: 4 x USB 2.0, Audio (AC’97 and HDA compatible) In and Out
- Washable air filter for quick, easy cleaning
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Dimensions: 480.5 mm (H) x 197.5 mm (W) x 477 mm (D)
Only £46.99 inc VAT.
ORDER NOW
- Cooling system
ORDER NOW
