**NEW ANTEC PRIZM RGB CASE FANS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Antec have a few variants of fan bundles to get you going on your RGB system. Brighten up your system with these addressable kits allowing you to change your fans to match your system or even match your mood.
Check out the following below:
Antec Prizm 120mm Addressable RGB Case Fans and LED Strips - Triple Pack @ £79.99 inc VAT https://www.overclockers.co.uk/ante...ans-and-led-strips-triple-pack-fg-043-an.html
Dual-sided RGB ring illuminates your PC, Addressable RGB, ASUS Aura Sync Ready, PWM fan optimizes heat dissipation and hydraulic bearing ensures ultra-quiet operation, Two Addressable Strips
Only £79.99 inc VAT.
ORDER NOW
Antec Prizm 120mm Addressable RGB Case Fans - Five Pack @ £85.99 inc VAT https://www.overclockers.co.uk/antec-prizm-120mm-addressable-rgb-case-fans-five-pack-fg-044-an.html
Only £85.99 inc VAT.
ORDER NOW
Antec Prizm 140mm Addressable RGB Case Fans - Dual Pack @ £49.99 inc VAT https://www.overclockers.co.uk/antec-prizm-140mm-addressable-rgb-case-fans-dual-pack-fg-045-an.html
Only £49.99 inc VAT.
ORDER NOW
Antec Prizm 140mm Addressable RGB Case Fan @ £17.99 inc VAT https://www.overclockers.co.uk/antec-prizm-140mm-addressable-rgb-case-fan-fg-046-an.html
Only £17.99 inc VAT.
ORDER NOW
All Antec Products Available Here
3 fans, 2 LED strips and the controller for £80 is a bargain!
they all support Asus, MSI and gigabyte RGB fan headers and software too :)
Ooooh. Shiny! I'll keep an eye on these as my gaming rig is poorly lit with just the emissive light from the AIO cooler. These fans will be perfect to brighten it up! That 5 pack is looking tempting!
Are these likely to increase in price after the pre-order period?
Prices will not increase after pre-order.
Stock could be about 3-4 weeks from now.
Good choice, these are supported by MSI, Gigabyte and Asus RGB motherboards.
Price should remain the same unless the GBP tanks in value, but then all component prices will go up.
I'm still rocking an MSI X99a SLI Plus mobo. So it would mean upgrading that along with the CPU as well and at the moment don't have those kind of funds.
On the Antec site it suggests that the controller is only compatible with Gigabyte motherboards, if this is the case how many fans can you daisy chain from an Asus header (not using the controller box) ?
Love that they are the onlys ones ive spotted so far that add the lighting to both sides of the fans, so if you want to use them in a pull config on a radiator for instance, you don't sacrifice loosing the lighting effect unlike my damn LL120's
This is where we are different, the controller has a control port on it which allows you tro cycle through the settings and is 2 pin, and is compatible with all standard case reset switches. So you can make your reset switch a LED cycle button.
These look pretty darn cool to be fair, will there be a package deal in with 140mm ones and led strips at all gents ?
so tempted to order but misses would kill me being so close to christmas
