**NEW AORUS X7 Pro - with nVIDIA G-Sync
AORUS Rep
Vendor Rep
16 May 2014
In the UK :-)
Arriving this week @ OcUK - AORUS X7 Pro with NVidia G-Sync
Great new GPU technology from NVidia will improve your gaming experience no end.
2 models of AORUS X7 now available with this technology:
http://www.overclockers.co.uk/showproduct.php?prodid=LT-013-AU&groupid=959&catid=1828 - arriving Wednesday 10th June
http://www.overclockers.co.uk/showproduct.php?prodid=LT-016-AU&groupid=959&catid=1828 - Coming very soon and equipped with a host of goodies including new 5th Gen core i7 processor
And of course our newest addition to the AORUS range - X5
http://www.overclockers.co.uk/showproduct.php?prodid=LT-012-AU
AORUS and OcUK, striving to bring you the best of the best, first !
Regards,
Gigabyte UK NB Team
Hi Atom80,
Do you have any information from Aorus yet about support for Windows 10 in the Aorus X7 Pro?
Microsoft have already advised that the laptop will qualify for the free upgrade, but it would be good to know if we can go ahead as soon as it is launched or whether Aorus intend to check out the compatibility first.
Thanks,
Chuffbaby
Hi Atom80,
Thanks,
Chuffbaby
Hi Chuffbaby,
Yes the machine qualifies for FREE upgrade, as you see from the notification.
We will check with HQ to confirm weather we envisage any additional downloads directly from us will be needed, so we will post accordingly.
Thanks,
Regards,
Gigabyte UK NB Team
Hi Chuffbaby,
Thanks,
Regards,
Gigabyte UK NB Team
Hi Atom80,
Do we have any update yet on whether we can go ahead with the upgrade to Windows 10?
Thanks,
Chuffbaby
Hi Atom80,
Thanks,
Chuffbaby
Hi Chuffbaby,
Yes. It’s okay for X7 Pro to upgrade from WIN 8.1 to WIN 10.
To ensure stability, we suggest following the instruction below:
1. Under Windows 8.1, install all Important Update items
2. Under Windows8.1, install all the drivers and utilities through Driver Update, except Macro Engine
3. Remove Macro Engine
4. Upgrade to WIN 10
5. Remove Intel Bluetooth Driver and Killer Lan Driver(Qualcomm Atheros Killer Manager Suite)
6. Install all drivers and Macro Engine for WIN 10 through Driver Update
That's should give you best result.
Hope that helps,
Regards,
Gigabyte UK NB Team
