I bought this Asus P6T Deluxe V2 from OcUK last week, got a D0 stepping 920 and 6Gb OCZ Blade from MM. Assembled it all in my case, connected it all up, powered on and it won't post.
The power and reset buttons on the mobo light, a press of the power switch and my fans connected to my PSU spin up, mobo powered fans don't move, gfx doesn't spin up either.
1 question I do have is the 8 pin ATX connector for CPU power had a blanking piece over half of it, I removed this and used an 8 pin connector. There is no mention of this being 4 pin in the manual, it just says 8 pin ATX. Was I wrong to remove the blanker?
Any help would be great.
Thanks
Thanks
