Man of Honour
- 17 Feb 2003
- Chelmsford
I've not long bought a Sony STRDH810 plus a set of Tannoy SFX5.1.
Generally it seems ok but i've noticed the AV Amp states it requires an impedance of 8ohms but the speaker specification state, and I quoute, the following:
Tannoy SFX5.1 specifications
PERFORMANCE
Recommended amplifier power 15 - 100 Watts
Maximum Sensitivity (2.83Volts at 1m) 85dB
Nominal impedance 6 Ohms
Frequency response (-6dB) 140Hz - 78kHz
Drivers HF: 15mm (0.59") titanium dome, neodymium magnet system
LF: 75mm (3.00") paper cone
Crossover frequency 4.5kHz (mid to high) 140Hz (to subwoofer)
Magnetic shielding Yes
Satellite Weight 750gms (1.65lbs)
Satellite Dimensions H x W x D 140 x 97 x 95mm (5.51 x 3.82 x 3.74")
Centre Weight 1.5kg (3.3lbs)
Centre Dimensions H x W x D 120 x 230 x 95mm (4.72 x 9.06 x 3.74")
Finish Silver or black
Supplied accessories Wall mounting brackets
25 metres (82ft 6") speaker cable
Optional accessories Satellite floor stands available in matching silver or black
Isn't the 6ohms a bit odd? Are these compatible?
The speakers do sounds a bit short and tinny, if that makes any sense? Chap in the shop says they are fine?
What do you think?
PERFORMANCE
What do you think?
