Was running a 8800GTX in my CM stacker but had to cut part of the backing plate because it would'nt fit,now i have a new motherboard and cant get my new card to fit because i have cut away the screw section.
sorry for poor description,just hard to describe it through text.
Il get a pic sorted.
As you can see,my current 4850 is being held up by a cable tie.
ive tried CM and they dont supply a new back section,is there anywhere i can get on to fit this case?also what is the technical term for this part of the case?
