new badminton racket - help please :)
2 Dec 2006
Hey guys, so im looking for a new badminton racket and the shops around where i live are so shocking they don't have anything worth trying. This posses a problem for buying a racket as i will be getting it online instead and won't have even felt it.
So my budget isn't set in stone but im aiming for around £55, nothing fancey as its not my main sport just to play with some friends and that at uni. Ill replace the strings if im finding it lacking some.
So what would you guys suggest? Really don't have a clue what to buy. I got my tennis racket from tennisnuts some time ago so im thinking of doing the same for my badminton racket unless you guys know of better places?
Cheers.
(new laptop lacking spell checker at the moment and im really naff so please forgive any mistakes)
Bigdave, have a read of this thread:
http://forums.overclockers.co.uk/showthread.php?t=18043792&highlight=badminton
Though he was after a cheap and cheerful racket, the same advice applies.
Other than that, if i were you, i wouldn't bother buying a racket without having at least picked it up beforehand. Just borrow a racket until you get to uni and when you're in Leeds get yourself down to a decent racket shop. Buying online you may end up wasting your money on a racket that really doesn't suit you and changing strings won't really have much of a positive effect; generally the strings that Yonex rackets, for example, are pre-strung with are about right to start off with (usually around 19-21lbs).
This is from tennisnuts website:
How To Choose A Badminton Racket?
tennisnuts.com guide to choosing a badminton racket
This particular excercise is fraught with pitfalls from our point of view because badminton players tend to be generally very knowledgeable anyway , and COST (or price ceiling) and AND BRAND LOYALTY tend to be major issues.
There are also a proliferation of rackets on the market currently , all at different price points , particularly from the big two....Yonex and Carlton...with very small points of differentiation.
It is, however our job to provide some basis or method of selection so here goes :
Generally speaking , the top-of-the-range rackets from each of the manufacturers tend to be extra stiff , and are more suitable for the advanced player , or the person with a fast swing or stroke.
The average club player should go for something with a bit more 'give' in the shaft i.e medium stiff or flexible.
Within that, the weight of the racket is obviously very important, with lighter rackets being 85-89g , and normally weighted ones being 89+g.
Test the string tension of the racket. Powerful, accurate hitters tend to like rackets with high-tension strings, but players with a lighter touch usually use rackets with low tension for more control.
Grip the racket. If you must grip too tightly, try another racket. Remember that you can get a racket regripped to fit your hand. Most players like a big grip because the racket feels more stable in their hand.
However, badminton is a game of angles and touch, and a smaller grip can give the extra flexibility you need to create winning shots.
Find a racket with a balance that suits your style of play. A racket with a heavy head gives your swing more momentum, a quality that is perfect for power hitters. An evenly balanced racket permits play that is faster and more flexible.
Find a suitable weight. Coaches say beginners should start with a heavier racket, as it provides more stability. Players can then graduate to lighter rackets. Lighter rackets are more manageable, allowing for faster play.
Don't be overly economical. The lower priced rackets are usually quite heavy because they are made of cheaper material. You will tend to use more arm movements rather than your wrist to hit the shuttle if your wrist muscle is not strong enough. This will lead you to develop bad habits.
Heavier rackets are mostly preferred by players who have much stronger wrists and can therefore make use of the weight of the racket to extract more power from it. So unless you are in this category, I would suggest you purchase one that is not too heavy.
Choose a grip size that you feel comfortable with. Generally, attacking players prefer bigger grips as they need to hold the racket more tightly to generate power.
Players who like to rally and make use of deception usually prefer a smaller grip so that the racket is easier to turn in their hands.
Use a head cover whenever you are not playing. Remember not to store your racket close to the central heating radiators, or leave it exposed to sunlight inside a car.
Source: http://www.tennisnuts.com/shopscr930.html
Good luck!!
I bought my last racket online and it worked out well but you need to do some research on what kind of racket (balance/weight/flex) will suit your playing style at least. I've got a Wilson Blaze racket, chosen as it's a good all-round racket - I'm a reasonable club player at best and mostly play doubles so a stiff, head-heavy one wouldn't have suited me. The initial strings were quite poor, thick and low tension, but restringed with Yonex at 24lbs I really like it.
A great site I found last year when looking for a new racket was http://badminton-racket.blogspot.com/ - there's lots of useful posts about generally picking a racket and some manufacturer and racket specific stuff too :).
Andrew - When you're experienced, as you obviously are if you use 24lbs comfortably, and have held, played and compared other rackets, then you can use that knowledge combined with your understanding of racket 'stats' and have a fairly good idea of how well the racket will suit you. This is much harder for someone without that background and reading racket reviews online, as you know, can send you round in circles with the amount of differing opinions which are mostly based on playing style!!
centralsports are pretty goo, I've bought 3 or 4 and their service has always been great. Although trying a racquet is best, even then, a lot of variables have an effect performance.
Balance and weight more or less go hand in hand. A head heavy racquet will give you an advantage in power on your forehand, but will possibly be harder to get in position for quick returns and backhand flicks.
If you have high racquet head speed, you can go for a more even balance, thus making defence easier and maintaining most of your power.
Stiffness of the racquet also plays a part, the more flexible the shaft, the greater the power, but the trade off is accuracy.
Tension and string choice imo is the single most important factor. Get a decent racquet and put good strings in at a tension suited to you. Beginners should be looking at a tension of around 20lbs,as for string choice, I've been through most of them. Yonex BG65 Ti would be ok at that tension, and should be fairly durable.
Personally, I tend to play with BG85 at 28lbs, but I usually have my strings changed out every couple of months depending on how much I am playing. I have bee off for the last year so that has saved me a bit of cash lol.
good luck with your choice!
