my ducati 999s has been sat on a battery charger that went faulty since oct last year resulting in what i presume was the battery going flat and no longer holder charge so i bought a new motobatt glass mat one and stuck it on and left it on charger. on trying to start the bike yesterday it just would'nt start. it was showing 12.4 on the dash which was normal for before when it always started without any issues.
it tried to fire up a few times but would'nt start fully and then everything seemed to reset on the dash and would then all switch back on again,
has anyone got any suggestions. only thing i can think is that maybe i havent tightened up the bolts enough on the battery or i think i may have put the charger lead and the pc lead next to the battery terminal and the actual pos and neg leads from the bike on top of them. would that make any difference?
also i have a booster pack if i used that to try and start the bike would it A cause any damage and B if it starts with the use of that would is suggest that i may have a fault battery. thanks
