New brakes + disks,Spongy.
7 Jan 2009
Old man got new Brake disks & pads fitted today,Although he said they feel spongy and don't slow down all that quick he really has to squeeze the pedal.
Normal as they need to wear in?
Did it include a brake fluid change?
If not they just need bedding in and will firm up. Some are just like that, some are firm straightaway.
If no BF change then something is seriously wrong. Has he checked the fluid level incase a line was nicked and it's leaking?
When you first get new disks and pads everything will be really soft and seem broken for the first 10-20 miles at least. Mine sorted themselves out come the end of the 40 mile drive home.
Pads haven't bedded into the discs yet, that is all.
If they weren't spongy before the brake change then it wont be the fluid full of air or anything.
A brake fluid change may help if the fluid is old and contains a fair amount of moisture but is not and cannot be "caused" by a disc and pad change.
^ that makes no sense. Changing pads / discs is the most common way of introducing air into the system and therefore should be checked / bled usually as a matter of course
It is you who is making no sense.
Do tell me where this air gets in when you replace pads and discs?
It is most likely due to the pad not bedding in yet. I have no idea how your dad drives or how many miles so can't tell you how long it takes for him to bed them in, but he will feel he needs to dig for them if he brakes hard and they won't retard as well until they are bedded.
Air in the lines?
I suggest you lot......
http://www.truro-penwith.ac.uk/pt/basic-motor-vehicle-mechanics-2/
:p :D
Might be worth checking that the retaining clip that keeps the pads in place is located properly. I did a pad and calliper change once and didn't do that resulting in brakes that felt very soft much like air in the system, no amount of bleeding would shift it but taking it to bits and starting again sorted it.
New Pads and Discs do not have even contact surfaces so to get good contact some flex takes place until both are bed in, this results ina spongy feel to the pedal. Once they are bed in, it should feel like normal.
Yes, winding in a caliper, incorrectly, will introduce air into the system.
I changed pads on a mk4 golf and no matter how careful I was, the brakes were complete cheese afterwards. A quick brake bleed all round solved the issue.
If you are retarded enough to pop one of the pistons out while pushing the other back in then yes, you would introduce air into the system obviously.
However you simply cannot get air into a closed system by simply pushing the pistons back normally.
I suggest you probably had a section of rusty master cylinder that the seal normally doesn't get used in normal operation but when you replaced the pads and had to "pump up" the pedal" you disturbed that rust which in turn caused the seal to be somewhat inefficient until you had bled (pumped) the pedal a bit more and re-seated it.
Air - impossible
Crap - highly possible if the system isn't serviced regularly
