New Build Advice: for Architectural programs
16 Oct 2011
Hi everyone, This is my first post AND my first build ever, so I'm a bit freaked out considering the money i'm putting into this (which probably isnt even close to what some of you would consider "high" budget!!). My budget is around £700 which for me is massive, but being an architecture student and completely fed up with crap ready to go computers in that price range, i've decided to go for a custom made one, which fits my requirements.
i'll will be using a lot of CAD software: such as AutoCAD, Rhino, VRay (rendering), sketchup, illustrator, photoshop and inDesign. and will very often be using several of these programs all at once. Rendering is the big issue, having had to wait for over 12 hours for an image to render fully. which is a pain.
I'll also be using it for occasional gaming (assassins creed / call of duty mainly) but not to the extend that i'm willing to pay WAY more for better graphics.
Would any of you be able to run over the list i've made and give me any advice at all concerning the hardware?
One thing i'm stuck on is intel vs AMD. and the amount of graphics i should put.
thanks a lot! i'm planning to order the parts tomorow and have it all ready by the end of the week (hopefully).
Processor:
AMD: Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) £83.99
Intel: Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor £167.99
Motherboard:
AMD: Gigabyte GA-880GM-USB3 AMD 880G (AM3+) DDR3 Motherboard [GA 880GM-USB3] £68.98
Intel: Gigabyte H61M-D2 Intel H61 Chipset (Socket 1155) DDR3 Motherboard **B3 REVISION** £54.98
Intel: Asus P8H61 PLUS Intel H61 Chipset (Socket 1155) DDR3 Motherboard **B3 REVISION** £69.98
Memory: Corsair Vengeance Blue 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit £95.99
Graphics Card: HIS ATI Radeon HD 6570 IceQ 1024MB GDDR3 PCI-Express Graphics Card £56.99
Hard Drive: (x2) Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM £39.98 (x2)
Power Supply: Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply £64.98
Cooling: Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler £19.99
Network LAN: TP-Link TL-WN781ND 150Mbps Wireless PCI Express Adapter £9.32
Monitor: BenQ V2200 Eco 21.5-inch LCD Monitor £133.85
Keyboard: Emprex 6310U-W Slim Desktop Keyboard USB White £8.99
Mouse: SPEEDLINK MYST Wireless USB Touch Scroll Mouse £13.83
Case: £30??
Windows 7: £30 student price
Total: depends on AMD or Intel
Processor:
AMD Phenom II http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM&tool=3
Intel i5 http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
Motherboard:
AMD: http://www.overclockers.co.uk/showproduct.php?prodid=MB-369-GI
Intel Gigabyte http://www.overclockers.co.uk/showproduct.php?prodid=MB-332-GI&groupid=701&catid=5&subcat=
Intel Asus http://www.overclockers.co.uk/showproduct.php?prodid=MB-453-AS&groupid=701&catid=5&subcat=
Memory: http://www.overclockers.co.uk/showproduct.php?prodid=MY-309-CS&groupid=701&catid=8&subcat=
Graphics Card: http://www.overclockers.co.uk/showproduct.php?prodid=GX-044-HS&groupid=701&catid=56&subcat=
Hard Drive: http://www.overclockers.co.uk/showproduct.php?prodid=HD-067-HI&groupid=701&catid=14&subcat=
Power Supply: http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN&tool=3
Cooling: http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR&tool=3
Network LAN: http://www.amazon.co.uk/TP-Link-TL-...xpress/dp/B0036AFAEW/ref=cm_cr_pr_product_top
Monitor: http://www.amazon.co.uk/BenQ-V2200-...1_2?s=computers&ie=UTF8&qid=1318205022&sr=1-2
Keyboard: http://www.amazon.co.uk/Emprex-6310...1_2?s=computers&ie=UTF8&qid=1318205524&sr=1-2
Mouse: http://www.amazon.co.uk/SPEEDLINK-W...23?s=computers&ie=UTF8&qid=1318205789&sr=1-23
Case:`
One more thing is if someone sees that i'm spending too much on a certain item unnecessarily , where i could instead invest it in something more usefull.. please let me know.
