Hi, I have decided its time to upgrade from my dusty old c2d, seems to be such more choice around now then there used to be which has me stumpped.
My bugdet was £800 but I think I can up that to £850+ if needed would prefer not to though.
So far i have come up with this list, though i'm not sure if there is better options out there and also would this all fit together (worried about heat sink's hitting ect)
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card £269.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
£179.99
MSI Z68A-GD65-G3 Intel Z68 (Socket 1155) DDR3 Motherboard £149.98
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-650TXV2UK) £79.99
Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £54.98
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) £44.99
Total :
£792.52 with postage
Is the cooler overkill? I plan on oc to around 4ghz and would like the peace of mind about over heating.
Not sure about a case was looking to spend around £60 on one which there doesnt seem to be many options, would like an interesting looking case with a window and supplied fans, I quite like the look of Zalman Z9 Plus Tower Case with Fan Controller - Black its out of stock but should be able to find it somewhere, would the above components fit in this ?
Any help / advice would be great, thanks
£179.99
Total :
