Hi all,
I'm thinking of putting a new build together next week, I'm wondering if anyone can take a look at my requirements and suggest some components?
I'm hopeful that I can salvage existing parts but I'm open to suggestions. My absolute max is £700, and if money can be saved even better.
I'm particularly interested in suggestions towards cooling, as it can get fairly dusty where my PC lives.
I do use my PC for gaming, and I use it for work (using VPN/RDP). I'm currently playing Guild Wars 2, and my fps in big pvp fights is pretty terrible (2-4fps), I also have Witcher 2 and Metro 2033 waiting to play. I suspect my system is bottlenecked by my ageing Athlon X2 250.
Here's a list of my current components (excluding my worthless PSU,CPU, Mobo and Ram):
EVGA GTX570 (SC edition)
Crucial V4 256GB 2.5" SATA-II SSD (used for my O/S + steam)
Seagate 2.5TB SATA 7200rpm Harddrive
I don't require a keyboard, mouse, or monitor. I'll also use a trial version of Windows 7 and, await for the next release before deciding on which O/S.
Thanks for any help you can offer
