All, I am just a dad trying to make a 14year old very happy. I am of the generation that did some builds in the past but that was some 15 years ago... Totally out of date but trying to hang on to what I used to know and using some common sense, after much reading, I have pulled together the configuration listed below, but would welcome some advice and positive feedback on whether this is a good build or what could be changed/improved or simply does not make sense. Technically substantiated feedback would be preferred as I would like to learn something out of this.
Note that I would like this to be an over-clockable machine with potential to grow too - I see this as a machine to keep long term with possibility to look into water cooling in the medium term...
- ASUS ROG Crosshair VIII Extreme
- AMD Ryzen 7 5800X3D
- Radeon RX6800XT Red Devil
- 32GB (2x16) Corsair DDR4 Vengeance LPX - PC4-25600 (3200) CAS 16-20-20-38 XMP2.0
- 2TB Corsair MP600 Pro XT
- Be quiet! Shadow Rock LP, Low-Profile Top Flow Single Tower CPU Cooler, 4 Heatpipes, 120mm PWM fan, 130W TDP
- 1000W Thermaltake ToughPower GF1, Full Modular, 80Plus Gold, SLI/Crossfire, Single Rail, 83.3A, 140mm Fan, ATX
- Fractal Pop XL Air RGB, White, Full Tower Chassis, 4x 120mm fans, USB 3.0, E-ATX, ATX, mATX,mITX
Does this setup make sense? Have I missed something? Is something incompatible or am I throttling something with one of the choices? Also graphics card wise, I went for the Radeon instead of a GeForce 3070ti because I understand AMD now splits game loading between CPU and GPU and not sure it will work with the Nvidia...? I found it a particularly difficult choice...
Looking forward to read your comments and advice! Thank you!
Luis
Luis
