Hi
Im new to the forum, but it looks like theres a fair amount of knowledgeable advice to be found on here, so im thinking of buying this lot:
Intel Core 2 Quad-Core Q6600 G0 SLACR, 95W
Asus P5K3 Deluxe/WiFi-AP, iP35, S 775, PCI-E (x16), DDR3 1066/667/800
Samsung SH-S202N/BEBN 20x DVD±R
2GB CorsairTwinX XMS2, DDR2 PC2-6400 (800) 4-4-4-12, DHX
Antec P182
2 X 500 Gb Seagate ST3500630AS Barracuda 7200.10, SATA300
320MB 8800 GTS
Arctic Cooling Freezer 7 Pro
620W Corsair HX Series Modular SLi PSU,
Creative SoundBlaster X-Fi Xtreme Gamer
22" LG L226WTQ ,Silver/Black , Widescreen ,2 ms , DVI/VGA ,1680x1050 ,3000:1
This lots comes to £1200 ish.
Couple of points:
a) I dont know anything about overclocking so therefore doubt i will be over clocking anything so stability is the preference.
b) I picked the mobo to be as future proof as possible (so i can buy some DDR3 ram at some point in the future)
c) Need a monitor i can plug an XBox360 into as well as the PC.
Any modifications / suggestions are welcome.
Cheers
Antec P182
320MB 8800 GTS
Couple of points:
Cheers
