Hi all *waves* Im after some of your good advice please.
Well... I have finally talked the wife into allowing me to build a new PC.
My build will cost 2k+ so I need to be sure about what im going to be buying.
Im looking at...
i7 940 2.93Ghz (custom HS&F with view to OC'ing)
6gb DDR 3 tri channel
Nvidia GTX295 (2nd card to be added at a later date)
2tb HD space
Asus mobo
Creative's Sound Blaster X-Fi Titanium (with front panel)
Blueray burner
PSU that will handle second G. card in future.
Windows Vista Ultimate 64bit
What do you recon?
Im looking for a case that will fit 2 x GTX295 cards in, what case would fit the bill? Im after a nice big case with very good cooling (not water cooling).
What is wrong with motherboard designers!!! I see a bit of a problem fittting a GTX295, PCI Express soundcard and then possibly later on a second GTX295. Cant find a mobo that will allow this...
Any advice welcome.
Im looking at...
2tb HD space
Asus mobo
Blueray burner
What do you recon?
Any advice welcome.
