Hi
Im looking to build a new pc for gaming, but havent been keeping up with hardware at the moment, so im a bit out of the loop. So if you guys could recommend some decent hardware that would be grand.
My budget is around 700, up to 900 if needs be.
I already have a monitor, mouse and keyboard, but need windows vista ultimate included. The budget is for the whole base unit, including a case.
The base unit will be used for gaming.
Is SLI / Crossfire worth it?
What CPUs and Motherboards are good for overclocking?
Is it worth buying 4gb of RAM worth it?
Many Thanks
Many Thanks
