New build advice
14 Apr 2007
York
Just about to order the below parts for a new build. I am going to be using a ATI HD2900XT for now and I will not be overclocking this compouter at all.
Can anyone see anything wrong with this build or any reason to change a specific part?
Everything looks fine to me but i would get E5200 as 0.1GHz won't make any difference and change OCZ to Corsair. Just my 2p. I'm sure somebody will correct me if i'm wrong :D
Don't know about the F1, but the old Sammy HD'd were/are quiet, don't see why the F1 wouldn't be.
But Ditto on the ram
Get the 64-bit version of vista if you want to address all 4GB.
^^ Snap.
Otherwise it's a waste of time having 4gb :)
My F1 has been smooth and quiet since the day i booted it up :)
+1 On the ram too :)
