Current PC is overheating (pretty sure its the mb). I have a core2 6600 (2.4ghz not overclocked), asus commando and 8800GTX. All of which I am assuming is now quite dated and slow compared to the latest stuff.
I havent looked at new hardware in over a year so no idea whats the best at the moment.
I will be running 3 monitors, and possibly 4 at a later date so it seems some sort of dual/sli graphics card is needed. I want huge raw power without overclocking the nuts off it and having it dead in a year (I will overclock as far as NOT altering voltage will allow me, i dont want it dying). I am also considering the possibility of watercooling.
So looking for recommendations for the following bits of kit
CPU (is it worth an 920 D0 stepping, will it clock to 950 level without upping the voltage? seems pointless getting a 950 for more than double the price if it will)
Graphics cards (3-4 monitor support required)
motherboard - top quality board, good for overclocking
memory (im thinking 4gb of whatever is fastest to go with the MB and cpu)
BD player and recorder
New case (mid tower or full tower, good support for watercooling needed), looks do not matter to me, practicality and quality does
Watercooling - would like to watercool the cpu and gpu's if practical if there is a relatively hassle free solution, would like the PC to be very quiet (or silent!)
I have monitors, a velociraptor and a 600w corsair psu so not looking to replace that unless i have to. I plan on getting an SSD but not yet, they are still too slow for my liking for the price.
I want a huge beast of a PC thats going to last me a good 2 years of gaming and general use so budget is no object within reason.
All suggestions appreciated, at least it will give me a starting point for more reasearch if nothing else.
Thanks
Wok
Thanks
Wok
