New Build - Advice
31 Aug 2010
Looking to Build a new PC that's mostly going to be used for gaming
I can Salvage a few bits from my old PC Antec 900 case and a 700w PSU
so far im looking at -
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail
Corsair H50-1 High-Performance CPU Watercooler
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
So i would need to add a Mobo and graphics card to this, having some difficulty choosing so i guess thats where you guys come in
MoBo -
id like USB3.0 and Sata 6Gb/s support should i decide to buy a SSD sometime in the next year secondly it needs to have space
for a PCI-e soundcard (which i already have) and a PCI wireless N card as well as the graphics card. im going to try overclocking
as well so maybe this needs to be taken into consideration.
Graphics card -
ok so im currently running 2x 19inch monitors at 1400x900, im thinking about buying a new 24 inch monitor so i can play games at
1920x1080 but rather than getting rid of my current 2 monitors i may as well use them in a 3 screen display am i right in thinking
i can do this with a single ATI card? using the 2 DVI ports and the 1 display port with a display port to DVI adapter?
so Budget for Mobo and graphics card im looking to spend around £300
