Building a new Pc and needs lots of advice pls
Spec:
Intel Core i7 950 3.06GHz
Asus P6X58D-E
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 -Want an Nvidia Card but really not sure which is the best to go for. £200 is the budget for it. I do plan on going Sli. But not for a long while. 460/465 seem to be my options
Patriot Viper 6GB (3x2GB) DDR3 12800C8 1600MHz
Samsung SpinPoint F3 1TB SATA-II 32MB
Antec 300 Three Hundred Ultimate Gaming Case - Really not sure on the case. Im looking for the most efficient Case in terms of cooling & cable management. Style comes second.
OCZ ModXStream Pro 700w - When I used PSUEngine I got 724W min and 774W recommended. That's with sli x GTX465, 3 HD, 1 SSD, 6xRam & Bluray drive
Prolimatech Megahalems - Read good reviews on this cooler. Willing to change though.
Sharkoon Silent Eagle 1000 120mm Fan - 3/4 Pin x 4 - 2 for the Megahalems. Was thinking of changing to PWM fans.Since the board has two 4pin connectors. Other two for Chassis.
Arctic Silver 5 Thermal Compound (3.5g) - This ok?
Samsung SH-S223L/RSMN 22x DVD±RW Sata
Samsung B2430H 24" - Wanted a monitor with 1920x1080 and HDMI in.
Spec:
Asus P6X58D-E
With only 4 fan connections what adapters will I need to add two more fans? Fan controller a good idea?1 x CPU Fan connector
3 x Chassis Fan connectors (1 x 4-pin, 2 x 3-pin)
1 x Power Fan connector
