Hi Guys.
Just putting together a new build and just wanted to run it past people to see if they had any advice to give me on components.
Ive decided to go down the overclocked I5 route and upgrade to an SSD.
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £159.98 (£133.32)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £155.99 (£129.99)
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) £147.98 (£123.32)
Corsair Graphite 600T Midi Tower Case - Limited Edition White £139.99 (£116.66)
Corsair Hydro H80 High Performance Liquid CPU Cooler £84.98 (£70.82)
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) £83.99 (£69.99)
To go with this I already have the following
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card
Asus Xonar D2X 7.1 PCI-E Sound Card
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI)
I'm going to be overclocking the CPU to about 4.4 - 4.5 with the closed loop water cooler but my only concern would be the GFX Card.. is a GTX 570 going to be limited by this set-up?
Would it be better to cash in the 570 and move to a 580 or possibly SLI with another 570?
Also would my current Corsair HX 650W ATX Modular SLI Compliant Power Supply be ok for this system or should i Upgrade that as well?
Thanks in Advance
Enigma
Thanks in Advance
Enigma
except I'll be going for dominators, a TJ07 and a custom watercooled loop.
