Hi All,
I would like to get back into PC gaming after a year long break so i'm looking for something that will be mainly be used for FSX but can play BF3/GW2 etc.
I have a copy of 7 + 1920x1200 monitor and keyboard/mouse etc all ready and plenty of big storage.
Budget is a maximum of £750.
I've been looking at the following but am open to the system builds option.
Gainward GeForce GTX 560Ti "448 Edition" 1280MB GDDR5 PCI-Express Graphics Card
(after using a SSD in the past would like to use a SSD again).
What do you recommend for RAM/case/psu/cpu cooler? Would this play ok?
Thanks in advanced!
Code:
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM
Code:
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
Code:
Crucial RealSSD M4 64GB 2.5 SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2
Thanks in advanced!
Thanks for all your help!
