New build advice
15 Apr 2003
Hi,
I am looking to build a computer which takes up as little space as possible, it'll just be used for mostly web browsing, basic spreadsheets. No games / videos.
Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
Antec ISK110 MiniITX Vesa Mountable Case - Black/Silver with 90W Power Supply
Gigabyte H61N-USB3 Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G)
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (GD38GB1333C9DC)
Akasa AK-CC7118HP01 K25 Low Profile CPU Cooler (Socket LGA775/LGA1155/LGA1156)
Would the above all work together fine? Do i need to add anything else? I have a copy of windows 8 already.
It's been years since i built a PC.
Thanks in advance.
Yes i think i will do that.
Also i think changing the motherboard to this should be ok:
ASRock H61M-ITX Intel H61 (Socket 1155) DDR3 M-ITX Motherboard [H61M-ITX]
To save a little more money. Would that also be fine?
Should be fine with that mobo
