Hi all,
Not built a PC since about 2008, so I'm a bit rusty on current specs, so please forgive any "obvious" mistakes.
I'm looking at putting together a gaming PC for my son at around £600. These are the comps I've put together, and was wondering if any body had any advice or can spot any mis-matches before I put the order in. Just need to build the base unit.
Went with AMD, only because I always used to use them in the past (better price/performance). Planning to run HDDs striped, with boot partition for OS, and everything else on another partition.
Also, should I go for windows 7 or 8?
Thanks in advance.
EPIC BUNDLE: AMD FX-8350, Gigabyte 990FXA-UD3, AMD 8GB 2133MHz Kit, Superflower 650W PSU & FREE STUFF!! **£30 SAVING**
Palit GeForce GTX 750 KalmX SILENT 2048MB GDDR5 PCI-Express Graphics Card
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
Aerocool GT Advance Black Edition Mid tower - Black
LG GH24NSB0 24x DVD±RW SATA ReWriter (Black) - OEM
Thanks in advance.
