New build advice.
12 Feb 2017
I am looking for some advice!
I need a new PC, I have a £500 budget and I need everything besides monitors.
I haven't built one for a few years so a bit out of touch with it all. I will be planning to dual boot Kali Linux, run three monitors, stream tv, and play a few games, a bit of wow. But I do not need to play on high graphics.
Any help would be appreciated.
Thanks
So you want to use 3 monitors but you only need 2 HDMI outputs?? :(
:confused:
There is a thread in the New to PC gaming forum (the top most forum on the main page) where a guy wants to build a 500 squid machine. You should use that build it's quite good and will suit your needs.
Check out the video cards and see if you can find a 1050Ti that has 2X HDMI outs. AFAIK the standard NVidia IO these days is 1 DVI 1 HDMI and a couple of DP.
here it is (that build):
These are all OC.co.uk prices
