New Build Advice
18 Jan 2024
london
Hey, 1st time using forums so be gentle. I am putting together a new PC and was hoping someone could give it a quick once over with knowledgeable eyes, to see if I haven't made any major mistakes.
Would hate to find out after a month that a few more quid here.. few less quid here would have helped.
I upgrade my PC every 3-4 years maybe swap out a piece in between a full upgrade. Play all types of games from city builders to shooters. Currently only playing at 1440p but a few 4k OLED monitors coming out have caught my eye so that's definitely on the horizon.
So have at it. All thoughts welcome. Ty for help in advance.
steve
  • 1x Lian Li Lancool II Mesh C RGB Midi-Tower Case - Snow Edition
  • 1x AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail
  • 1x Asus Prime X670E-Pro WIFI (Socket AM5) DDR5 ATX Motherboard
  • 1x NZXT Kraken 360 Elite White RGB AIO CPU Water Cooler - 360mm
  • 1x Corsair Vengeance EXPO 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit
  • 1x Sapphire Radeon RX 7900 XTX Nitro+ Vapor-X 24GB GDDR6 PCI-Express Graphics Card
  • 1x Thermaltake Toughpower PF3 1050W ATX3.0 Native PCIE 5 Fully Modular 80 Plus Platinum Power Supply
  • 1x WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T3X0E)
  • 1x Build Stock Microsoft Windows 11 Home Advanced - Systems
How much are the individual parts? We can't really comment without knowing how much you're paying.
In particular, that 7900XTX?
You might be better off waiting on the 4080 Super or 4070ti Super.
Hi and welcome.
Be aware you can only put a 360mm aio in the front of the lancool 2 and a 240mm up top.
The Lian Li Lancool 216 has room for a roof mounted 360 aio and if you get Lian li aio all the fan's RGB will match.
Hey TY for reply. Spent about £3k total
GPU was £1K
MOBO just shy of £300
RAM £130
CPU cooler £270 ish
PSU £180
CPU £390
Nothing really stood out to me as massively overpriced. Maybe the CPU cooler. I've always just thrown a massive air cooler on and been happy. Just mixing it up a bit.
Nice tip about the cooler. That size didn't cross my mind.
That was the one I was least happy about anyway. Yeah definitely worth a think on that one.
ty
A 240mn will be good enough for the 7800x3d , could go air take a look at the Thermalright Peerless Assassin 120se performance king.
