So i have a new system but some problems with these fans.It is probably the last thing i need as the GFX card i bought a while ago has the wrong voltage on the bios and cannot run BF3 without instant black screening.Was led to believe it lacked the OC bios not wrong voltage set for OC.
Going by OCUK these fans are expensive and apparantly ultra quiet.Turned out that they all electric motor buzz and have a ticking like a wire hitting the fan blades.And with 3x120mm via 4pin - molex and a 140mm side panel fan pwm down to 900RPM too still has a buzz.So even at lowest possible RPM the whole case has a slight buzz and ticking sound.
Worst yet is with Demcfilter the side 140mm apache cannot pass air to the graphics card unlike the other 120mm case fans with same filter.There is simply nothing going through at all not a whisp of air.The air actually comes out around the rims of the fan inside the case like a graphics card fan.
They were bought like 1 yr ago only used this week.Basically £50 down the drain then or is there an RMA or warranty on these things? Im not alone as the rainforest has a review i wish i read on the electric motor buzz of akasa apache case fans.
