new build and case
18 Dec 2003
heybridge, nr maldon, essex
hi
looking for a new case to build a 2500k system in.
i built a pc for my dad in a coolermaster 690 2 advanced and was impressed by the look and build and features. that was £75.
is there anything up to £50-60 del with those good features or should i stick to the light version which is available for £60 del.
any other good ones to consider? HAF 922 or silverstone RV02.
saw that on another thread but want something tool free if poss and front facing hdd slots - when side is open.
look sgood quality though must say.
tool less is gimmick IMO, as you still tend to need to use a screwdriver to tighten them anyway, plus unless youre constantly tinkering with your system then its only the initial build anyway
what you can do is mount the HDDs backwards, so the back is at fron of case, and use cable management to run cables down the far side of the HDD caddy, looks nice and neat this way
It is a very good case for the money, but case is very much personal choice so its what youre happy with
