Hello guys I am planning on building a new pc in the following weeks these are the components I have chosen so far. The computer will be used for gaming, programming, rendering and 3d animation.
Cpu http://www.overclockers.co.uk/showproduct.php?prodid=CP-358-IN&groupid=701&catid=6&subcat=1859
Intel Core i7-2600k 3.40GHz
Cpu cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC
Noctua NH-D14 Dual Radiator CPU Cooler
Motherboard -currently waiting for z68 boards-
Psu http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-CS
Corsair Professional Series™ Gold AX1200
Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM
Coolermaster HAF X Gaming Tower Case
Ram http://www.overclockers.co.uk/showproduct.php?prodid=MY-060-GS
G.Skill RipJawsX 8GB (2x4GB)
Hdd http://www.overclockers.co.uk/showproduct.php?prodid=HD-082-SA
Samsung SpinPoint F3 1TB
Graphic card - not really sure which one to go with I play on a 40inch lcd tv at 1920 x 1080, these are the cards which I had my eyes on.
1, MSI ATI Radeon HD 6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card
2, MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card
3, Asus ATI Radeon HD 6970 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card
Which graphic card do you guys recommend (not only limited to these) and are there components I should change, max budget is £1400 thanks.
