- 17 Feb 2023
- London
Been a good few years since I've built a PC and just wanted to check I'm not totally out of the loop. Was looking to put together a high end build as now have the time and money to put it to a bit of use. Only real stress for it will be gaming, have a G9 monitor so 5120 1440 at high FPS is basically what will be going for, mainly first person shooters and the occasional simulator. On the motherboards, going with AMD for the 7800x3d and MoBo might get another generation but not sure why they have got so expensive, am I missing anything in b650e v x670, I don't need multiple PCIE devices and wont need a million USB ports but is there anything major different apart from some additional PCIE lanes? B650E seems to have everything I would need and room for any realistic changes in next couple of years or am I wrong? Then RAM I am assuming isnt such an issue with the 7800x3d. Also want it to be quiet, but is the silent loop overkill. Then finally I could go top end GPU but also slightly amused/amazed that they are now £1600+, I am assuming at 5120 x 1440 a 4090 is just a waste of time. Have left out case and power supply as not sure on GPU, and open to suggestions, no interest in looks/RGB more focus on quietness/performance.
- 1 x AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail (SKU: CP-3DT-AM) = £439.99
- 1 x AMD Ryzen Game Bundle - Star Wars: Jedi Survivor (SKU: XX-03C-AM) = £0.00
- 1 x Asus ROG Strix B650E-E Gaming WIFI (Socket AM5) DDR5 ATX Motherboard (SKU: MB-6JW-AS) = £364.99
- 1 x Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit (KF560C36BBEK2-32) (SKU: MY-29T-KS) = £128.99
- 1 x be quiet! Silent Loop 2 280 High Performance CPU Water Cooler - 280mm (SKU: HS-01X-BQ) = £129.95
- 1 x Crucial P3 PLUS 2TB M.2 2280 PCI-e 4.0 NVMe Solid State Drive (SKU: HD-07B-CR) = £139.99
