Hi everyone,
I have just bought lots of new parts from OcUK for my second ever build, so I'm still rather inexperienced so bare with me
After putting everything together the first problem I encountered was that the red ram light would come on, and after about 10 seconds the pc would restart itself. Niether time would it post to monitor.
After playing around with the RAM, and trying the memOK button, I have deducted that any RAM combination with B1&B2 works fine (and I get post to monitor and can play with the bios), but if I put RAM in either A1 or A2 (left hand side on mobo when standing upright) it will fail to post and that red light would come on (even if there is RAM in B1/B2 which I know works).
After some google searches it seems like the problem is either with the motherboard or cpu (for the record it is an Intel 2500k with this cooler: http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD). THis leads me to believe when I come home from work tonight I need to try the following things:
-CMOS restart - I don't really understand what this is or how to do it
- Loosening off the cpu cooler - Apparently this can 'warp' the motherboard if too tight and may cause problems with ram detection (though it seems weird it won't start when there is RAM present in A1/A2 and B1/B2 knowing the B side seems working, it obviously must know something is in the A side to throw a problem)
- Checking the CPU seating and for any bent pins - Given that the cpu only fits in the socket one way, and there is a mechanism for closing the latch down I don't really see how it can't be sitting properly. I suppose I will have to check for bent pins either way though (will I have to reapply the thermal paste after taking the cpu cooler off? Or do you only need to do this when you put in a completely new cpu cooler?)
If there is anything else you can think of please let me know, I would like some reasurance that the tests above are relevant to my troubleshooting.
Thanks in advance.
Thanks in advance.
