Hi everybody,
im hoping someone can help me out please, bought a whole load of new gear yesterday:
i7-3770K
MSI Z77A GD55 MB (1155)
Corsair TX 650 W v2 PSU
Corsair Vengeance 2 x 4gb DDR3
Corsair Force Series 3 120gb SSD
Corsair Hydro H80 CPU coller
GTX 560 ti GPU
also got a additional 1TB HDD DVD RW and Cooler Master CM690 case
spent most of last night fitting it all up, everything is fitting ok and looks to be plugged in correctly, CPU went in fine, cooler went ontop ok. all fans connected, front case switches all connected, 24pin PSU plugged into MB etc etc.
the problem i am having is the PC will no boot, when you hit the poweron button the power button on the MB turns on, the fans start to spin, then stop, 2 or 3 seconds later the power light on the MB has gone out. cant get anything to display on the screen
even the HDD dont seem to be spinning up or anything.
so i removed the GPU, the SSD and left it with 1 stick of RAM and the standard HDD and tried again. just incase any of these were causing issues. but the problem persists, turns on, then just goes straight off again.
it was getting fairly late last night so i decided to sleep on it then just double check everything tonight when i get home. i.e take it all out and put it all in again making sure i havnt missed anything connectors wise.
my main question is, is there anything obvious i might be missing. do i need anything other than the 24pin cable from the PSU to be connected the the Mainboard. is there any thing i can check to narrow down the potential problem a bit, could this be a faulty MB or PSU? im not sure the fans or anything would start to spin if the PSU is faulty so i assume that is ok?
any help/ advice is much appreciated, hopefully just taking it apart and putting it back together will sort it out. but if anyone can think of anything that will help?
thanks everybody
Batez
i7-3770K
GTX 560 ti GPU
thanks everybody
Batez
