I'm trying to build my new system but having switched it on there's nothing being displayed or no output of any kind on the monitor.
My new components are:
XFX ATI Radeon HD 5850 1024MB GDDR5
Asus Crosshair IV Formula AMD 890FX (Socket AM3) DDR3 Motherboard
AMD Phenom II X4 Quad Core 965 Black Edition 3.40GHz (Socket AM3)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply
Antec 300 Three Hundred Ultimate Gaming Case
Samsung SpinPoint F3 500GB SATA-II 16MB Cache
I have my old system plus a second monitor so I'm able to do some testing.
I know for certain it's not a monitor issue as my main monitor and test one both work fine on my old system.
So, on to the system itself. I've tried putting my old gfx card(8800GTX) in to my new system but that doesn't work either. I tried putting the 5850 into my old system but it doesn't work. But this is probably due to it not being compatible.
Having put my entire new system together I've now stripped in right back to just the motherboard, cpu and ram in the case with the gfx card.
Because I can't test the 5858 in another system I don't know if my problem is the gfx card or the motherboard.
Anybody got any ideas? Anyone familiar with the Asus Crosshair IV and know if I'm missing anything? Could it be a power issue?
