To be honest I think I screwed up and ordered the wrong ram (too fast)please have a look and see what you think.
System will not post,when it does I might be able to use windows for a while then I get a blue screen etc
Also the only way it will boot is if I remove one stick of ram!
SPEC
Corsair 2GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x1GB)
Intel Core 2 Duo E6700 "LGA775 Conroe" 2.67GHz (1066FSB)
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2
Raptor X 150 time 2
Asus 8800 GTX time 2
Enermax Liberty 620W PSU
If anyone has an experienced view please would you share it with me as this is doing my nut in.
Thanks
SPEC
Raptor X 150 time 2
Thanks
