New build, can't connect via Remote Desktop Connection.
Permabanned
29 Aug 2005
Reppin' up North London
Hi,
I get this error when I try to connect to my PC through Remote Desktop Connection : "unable to log you on due to an account restriction".
I remmember having this issue on my 'rents PC but I can't find the fix. It was a registry fix I think :s
Thanks in advance.
MC_Bob
what u using?
is its ms rdp then go to mycomputer right click properties remote tab tick allow users to
then select user.
Im on X64 but its the same for the X32 version of XP
That doesnt help either, still the same.
MC_Bob
Found the problem, thanks for your help.
The last suggestion triggered my memory and I remembered how to do it
MC_Bob
