New build check/advice
18 Oct 2002
Derby
Was just wondering if you guys could check over my proposed new build that I intend to use for general use & the odd bit of gaming, my original budget was £550-£600 but sadly looks like its going to go over that by the time I'm done so any recommendations would be welcome...
Gigabyte GA-Z77-DS3H Socket 1155 Motherboard
Intel Core i5 3570K 3.4GHz Socket 1155 CPU
Sapphire HD 7850 OC Edition 2GB Graphics Card
Antec Basiq VP550P - Power supply
Crucial 128GB M4 SSD - 2.5" SATA-III
I'm also looking at banging in 16gb RAM, DVD writer & a not too expensive case. I've got O/S & monitor for now :)
Cheers
Thanks for the reply, it was the Z77-D3H that I had selected, anyway I assume the PSU at 550w is adequate? Any other advice on this setup?
