Ok people got it today, A lian Li 343 case. Need to install into her my water cooling consisting on a PA120.3 and a unknown 120.2 rad.
The PA can go in *** front one side, stood up, but do I need these or do they even fit (heard they dont fit the thermochil rads?)
http://www.overclockers.co.uk/showpr...d=7&subcat=187
My Corsair 520w psu, where it is to be mounted here is a grill below so you could mount in so the flow blows/suck(dont know which way Corsairs PSU flow) through the floor, shall I do this or shall I have it so fan point up into my case? the case is on wheels so whould get a fair amount of air under case.
Fans I have:
2X 80mm (for rear)
4X Yate loon Low speed
5X 120mm HDD bays http://www.overclockers.co.uk/showpr...d=7&subcat=187
What fans should I mount where? push or pull? Shall I get a few more?
Im connecting to a Zalman fan controller which has 4 channel,s now I want to connect up more than 4 fans so I know I can link them, but how do you do this? cant cut the cables as I need the end connector to plug into fan unit if you know what I mean, how can I join them, can I use a connector block, but how do i keep fan connector on 1?
Any help would be great, I know theres a lot there.
Thanks very much
Sheldon
Fans I have:
2X 80mm (for rear)
Thanks very much
Sheldon
