- 5 Aug 2020
As mentioned in the title I recently built my first PC but the CPU is always at 4.2Ghz (the max for a ryzen 5 3600) and never goes down. Going to power options in the control panel, switching between all the options does nothing except in power saving mode where it halves the clock speed to 2.1Ghz. If it helps I have an MSI B550 Gaming Edge WiFi. The CPU always being at 4.2Ghz even when at idle causes the temps to be higher when there is no need for them to be... Help appreciated!
SOLVED - I reset the CMOS and reseated the CPU and it fixed itself (but it only shows in Ryzen Master properly)
I think they are now bundled into the latest chipset drivers so its likely those bad boys you need.
