New build cpu and gpu help!
10 Jul 2013
Space
Hi so I’m starting to get my act together on a new build it’s going to be a work/gaming rig. Work wise I will be creating car concept art, photo/video editing etc and game wise I play everything really. I’m going to be doing this on a 32 inch 4K monitor, I’m not fussed about amd/intel/nvidia just what will be the best overall package. Budget wise I am trying to keep cost down so even if an older threadripper (1950x) is good I’m ok with buying used. Cheers peeps
few site should help gauge your hardware requirements to budget
GPU
https://www.pugetsystems.com/labs/a...-Roundup-NVIDIA-SUPER-vs-AMD-RX-5700-XT-1564/
https://www.pugetsystems.com/labs/a...-Roundup-NVIDIA-SUPER-vs-AMD-RX-5700-XT-1563/
https://www.pugetsystems.com/labs/a...-Roundup-NVIDIA-SUPER-vs-AMD-RX-5700-XT-1553/
https://www.pugetsystems.com/labs/a...-Roundup-NVIDIA-SUPER-vs-AMD-RX-5700-XT-1552/
https://www.pugetsystems.com/labs/a...C-2019-Enhanced-Details-GPU-Performance-1366/
CPU
https://www.pugetsystems.com/labs/articles/Lightroom-Classic-CC-2019-CPU-Roundup-Intel-vs-AMD-1298/ < no latest ryzen 3000
https://www.pugetsystems.com/labs/a...adripper-2-Intel-9th-Gen-Intel-X-series-1538/
https://www.pugetsystems.com/labs/a...MD-Ryzen-3rd-Gen-CPUs-for-Video-Editing-1522/
https://www.pugetsystems.com/labs/a...adripper-2-Intel-9th-Gen-Intel-X-series-1529/
https://www.pugetsystems.com/labs/a...adripper-2-Intel-9th-Gen-Intel-X-series-1535/
ram - for ryzen 3000 and intel z390 then fastest ram does help! going x299 boards from either then it doesn't , more ram helps
https://www.pugetsystems.com/labs/articles/Does-RAM-speed-affect-video-editing-performance-1528/
