I'm in the middle of my first ever 'serious' build and taking things very steadily. A bit tense but also perversely enjoyable
Having felt very pleased at successfully placing the Megahalem on the i7 920 followed by the Corsair Dominator 2000mhz cooler next to it I think I can see a problem!
The ram cooler is obviously going to affect the flow through the Megahalem. So some questions assuming that my assumption is correct.
Should I turn the cpu cooler through 90 degrees so that the air is being pushed towards the large fan at the top of the Antec 1200 case? I also have another Noctua fan; should I use this to pull air through as well or will one suffice?
Any other suggestions?
Thanks.
Thanks.
